girtab Posted September 26, 2016 Share Posted September 26, 2016 (edited) Hi, I have a problem with Houdini, yesterday i have try some modification in different nodes (in type propetries ) for testing, but now i dont know what i did and my mantra node looks totaly different. i have uninstall houdini but i have always this problem, what can i do, can i reset all the node ? Edited September 26, 2016 by girtab Quote Link to comment Share on other sites More sharing options...
Atom Posted September 26, 2016 Share Posted September 26, 2016 (edited) You can lock in changes you make to nodes so they become system defaults. But that requires a specific action on your part. If you did not do that then all you have to do is delete the node an create a new one. The new one will be created using the system default parameters. You can also reset any field value to it's default by right-clicking on the label and choosing Revert To Defaults. Edited September 26, 2016 by Atom 1 Quote Link to comment Share on other sites More sharing options...
girtab Posted September 26, 2016 Author Share Posted September 26, 2016 nop i can't do a revert to default. For changes its here ? (image) i want to my node returns by default Quote Link to comment Share on other sites More sharing options...
michael Posted September 27, 2016 Share Posted September 27, 2016 put down a new mantra ROP MMB on it and see where it's type is being defined - you might have saved a custom one locally you can also use the Operator Type Manager to find all definitions of the mantra ROP - delete any that don't cone from the Houdini File System ($HFS) 1 Quote Link to comment Share on other sites More sharing options...
girtab Posted September 27, 2016 Author Share Posted September 27, 2016 thx all it's good for me now !! Quote Link to comment Share on other sites More sharing options...
