tn2josh Posted September 27, 2016 Share Posted September 27, 2016 I'm following along a tutorial that uses Houdini 12. I'm on Houdini Indie 15.5. There are a few things that have changed (new check boxes and expression names) and what I'm doing isn't working as it appears to be in the tutorial. There is probably a few ways to do this... I'm open to suggestions, but I want to also understand what changed or what I might be doing wrong. I have two sides of my node graph. One is a Grid plugged into a Mountain (to displace). The other side is a Sphere plugged into an attribute create which I've made an attribute called meshPush. Both sides are piped into an attributeTransfer. Finally at the bottom, there is a point node where I am supposed to add an expression to the Y position to displace my grid using the sphere. When I try to add my expression to position Y (@P.y + $MESHPUSH) that actual attribute isn't working and not actually showing up. Hope this makes sense. Can someone take a look and let me know why this might not be working properly? Thanks in advance from a new Houdini user. Learning_01.hipnc Quote Link to comment Share on other sites More sharing options...
Sepu Posted September 27, 2016 Share Posted September 27, 2016 (edited) You need to check in the attribute create node "Local Variable" and then play with the "Blend with", etc in the attribute transfer. here is the setup working. I would recommend moving away from local variables as much as you can since is being replace anyway. Attributes is the way to go. "@pushgrass" way more efficient and faster. And also from the Point Node. Learning_02.hipnc Edited September 27, 2016 by Sepu Quote Link to comment Share on other sites More sharing options...
tn2josh Posted September 27, 2016 Author Share Posted September 27, 2016 thank you for your help! that fixed it perfectly. do you mind explaining and/or uploading a version that shows how this would look without local variables? Quote Link to comment Share on other sites More sharing options...
Sepu Posted September 27, 2016 Share Posted September 27, 2016 Attached is version using attributes. There is a Attribute Wrangle and Attribute VOP doing the same thing, both are valid solutions, it just depends what you prefer. Learning_03.hipnc Quote Link to comment Share on other sites More sharing options...
