leytonian Posted October 1, 2016 Share Posted October 1, 2016 Hi The file node is refusing to load .objs ;( It keeps saying that it is unable to read the file. I tried many many objs and I get the same results meanwhile other apps like Modo or Zbrush have no problem with these objs. In fact I was able to load these files just couple hours ago in Houdini as inside my Houdini project files. I have no idea about what happened ;( Quote Link to comment Share on other sites More sharing options...
Atom Posted October 1, 2016 Share Posted October 1, 2016 If they worked before they will work again. Perhaps you Set the Project or did a Save As which might break references such as $HOME or $JOB. Try browsing directly to the file with a full path. Also, if you object has a number in the name and it is not a sequence perhaps you moved the time line playbar? If it is not a sequence make sure you don't have a $F variable in the file name. The default dialog will put that $F in your filename unless you turn off that checkbox. Quote Link to comment Share on other sites More sharing options...
leytonian Posted October 1, 2016 Author Share Posted October 1, 2016 @Atom Thanks for the reply. Actually it was none of those things. I had to move the Houdini program folder to a network drive due to space left on my system drive but it looked like Houdini did not like that at least certain Houdini executables did not. Quote Link to comment Share on other sites More sharing options...
