[SOLVED]Access prim attribute inside Point Wrangle
vtrvtr
Hi
Pretty much the title
In VOP I can use the "Import Primitive Attribute" node to do it, but I'm not sure what's the recommended way to do the same in a wrangle. I noticed that the IPA node is actually just a snippet, which obviously answers my question, but I was wondering if there was a more straightforward (a.k.a shorter) way to do the same
Thanks
EDIT
Someone answered my question and apparently just using @primnum works in wrangles. However, now I'm more confused. I created a sphere and put a
f@test = @primnum;
in a point wrangle, the results are some numbers, but what do these numbers refere to?
Edited by vtrvtr
Question answered but now I have a different question
If you turn on 3D viewport point numbers and primitive numbers you will see the correlation.  In this image point #93 belongs to primitive #115.
You can also fetch attributes directly from a primitive if you know it's index.
v@Cd = prim(0, "Cd", some_primitive_index);
Edited by Atom
Yeah, I did that, that's how I got to see the numbers in the first place
The thing is it was some funny numbers, like really weird like 3.495*10^-8, which is why I asked. I guess I did something else when I tested. Unfortunately I closed the file, so I can't check
Well, sorry for the silly question, thanks, Atom!
