lyansart Posted October 19, 2016 Share Posted October 19, 2016 Hi guys! I did a model on maya and the texture in mari and i'm trying to shade it in mantra, but if i plug the UDIM textures in the material i can see the texture in the viewport but not in the render view :/ does somebody knows why and can help me? thank you Quote Link to comment Share on other sites More sharing options...
Atom Posted October 19, 2016 Share Posted October 19, 2016 What material did you apply to your model? Quote Link to comment Share on other sites More sharing options...
lyansart Posted October 19, 2016 Author Share Posted October 19, 2016 31 minutes ago, Atom said: What material did you apply to your model? I've tried with a mantra surface, is that wrong? :/ Quote Link to comment Share on other sites More sharing options...
Atom Posted October 19, 2016 Share Posted October 19, 2016 (edited) No, that is correct. I just wanted to make sure you had not simply used some OpenGL shader instead which might only offer viewport support. I have not done a lot with UDIM textures, but I know there is a check box, right above where you specify the image map. UDIM Filename Expansion. Have your tried activating that? Also try just assigning any old material to the diffuse slot and see if that renders. Try to figure out if it is UDIM specific or not. Edited October 19, 2016 by Atom Quote Link to comment Share on other sites More sharing options...
lyansart Posted October 19, 2016 Author Share Posted October 19, 2016 8 minutes ago, Atom said: No, that is correct. I just wanted to make sure you had not simply used some OpenGL shader instead which might only offer viewport support. I have not done a lot with UDIM textures, but I know there is a check box, right above where you specify the image map. UDIM Filename Expansion. Have your tried activating that? Also try just assigning any old material to the diffuse slot and see if that renders. Try to figure out if it is UDIM specific or not. with a random material it's rendering, and the weird thing is that in the viewport is showing the textures in the right place, and in the render view.. just nothing! :/ I've checked Use map and Udim filename expansion in the mantra surface :/ but yet nothing, if i render with a baketexture it's showing only black and white textures :/ Quote Link to comment Share on other sites More sharing options...
Atom Posted October 19, 2016 Share Posted October 19, 2016 Maybe it has something to do with the name of the UDIM image files themselves. Like there is some illegal character or SPACE that is messing up Mantra..? What about duplicate geometry in the exact same space? Kind of grasping at straws here without any example files. Quote Link to comment Share on other sites More sharing options...
lyansart Posted October 19, 2016 Author Share Posted October 19, 2016 (edited) 4 hours ago, Atom said: Maybe it has something to do with the name of the UDIM image files themselves. Like there is some illegal character or SPACE that is messing up Mantra..? What about duplicate geometry in the exact same space? Kind of grasping at straws here without any example files. you're right sorry, Here is my hip with the model and the textures.. I changed the name in the UDIM extension as %(UDIM)d or it wouldn't read them Edited October 19, 2016 by lyansart Quote Link to comment Share on other sites More sharing options...
Atom Posted October 19, 2016 Share Posted October 19, 2016 It seems to work for me. What I did was throw away your old Mantra ROP node and then created a new Mantra Surface and tried the UDIM filename you had setup in the other Mantra material node. Try my HIP with your assets. ap_shield.hipnc 1 Quote Link to comment Share on other sites More sharing options...
lyansart Posted October 19, 2016 Author Share Posted October 19, 2016 6 minutes ago, Atom said: It seems to work for me. What I did was throw away your old Mantra ROP node and then created a new Mantra Surface and tried the UDIM filename you had setup in the other Mantra material node. Try my HIP with your assets. ap_shield.hipnc the problem was i didn't typed the point after the texture name. It's so weird that it was showing in the viewport and not in the render anyway Thank you so much by the way, you saved me from a lot of headache! Quote Link to comment Share on other sites More sharing options...
