art3mis Posted November 1, 2016 Share Posted November 1, 2016 (edited) Hi Creating a simple FLIP simulation with some geometry(extruded letters) falling into a FLIP tanl. I originally created my tank at a size of 4 x 21 x 18 But then I realized if I want to create a 'table top scale' simulation, I needed to reduce the size of my FLIP tank. So I changed it to .4 x 2.1 x 1.8. I kept everything else the same except I also reduced the size of my falling geometry (the letters HELLO) to 10% of their original size. My Particle Separation remained the same at .025. My Feedback value remained the same at 0.4 But, when I run the simulation, it seems to 'break'. ie there is NO splash at the surface. Do I need to alter some other parameter, ie Density, or increase my Feedback? Why shouldn't the simulation work more or less the same if I am keeping my Particle Separation consistent? Attached are a few screen grabs Edited November 1, 2016 by eco_bach Quote Link to comment Share on other sites More sharing options...
Atom Posted November 1, 2016 Share Posted November 1, 2016 You may not have enough Volume density on your letters for them to register as collision objects, thus no splash. Quote Link to comment Share on other sites More sharing options...
art3mis Posted November 1, 2016 Author Share Posted November 1, 2016 Thanks Atom. Will give that a try. I'm only half joking when I say SESI should be compensating you for your amazing contribution to this community! Quote Link to comment Share on other sites More sharing options...
art3mis Posted November 2, 2016 Author Share Posted November 2, 2016 Came across this old thread with a supplied file from johner(illusionist). Going to study it and see what makes sense. I assumed to get accurate FLIP sims you need to work to scale, but apparently that's not the case. Quote Link to comment Share on other sites More sharing options...
