art3mis Posted November 12, 2016 Share Posted November 12, 2016 When using a RBD object, you can define initial Position, Rotation, Velocity as well as Angular Velocity. But what if you want to define an initial 'Rotational Velocity'? Can this be done using a simple VEX expression or? Quote Link to comment Share on other sites More sharing options...
mestela Posted November 13, 2016 Share Posted November 13, 2016 Angular velocity is rotational velocity, unless I'm missing something (which is highly likely). From the docs: http://www.sidefx.com/docs/houdini/nodes/dop/rbdpackedobject#initial-state Angular Velocity Initial angular velocity of the object. This is the axis of rotation times the rate of rotation. Speed of rotation is measured in degrees per second, so a value of 360 will cause the object to rotate once per second. Quote Link to comment Share on other sites More sharing options...
catchyid Posted November 13, 2016 Share Posted November 13, 2016 yes, rotational velocity is angular velocity... you could type HScript in the parameters to define them as you wish. I am sure there is a way to type VEX too but my question why do you need to do that? Is there something you can do in VEX and you cannot do in HScript? Quote Link to comment Share on other sites More sharing options...
art3mis Posted November 14, 2016 Author Share Posted November 14, 2016 thanks ,I assumed angular velocity had nothing to do with rotation Quote Link to comment Share on other sites More sharing options...
badboy2020 Posted May 22, 2021 Share Posted May 22, 2021 here is the file with angular velocity ParticleControlledRBD_V003.hiplc Quote Link to comment Share on other sites More sharing options...
