[FLIP fluid] Keep primitives(remove particles) after DOP import
art3mis
Ok so I've done the opposite using a Blast, removed all primitives from my DOP import in order to properly convert and surface my particles. But now I want to remove the particles, keeping only my primitive geometry after my DOP import.
I'm trying to also use a Blast but have been unsuccessful so far.
And then hopefully merge these primitives with my surfaced particles to just a single RENDER (null) node.
My end goal is to just have a SINGLE render pass for a FLIP sim with primitive geometry under water. Not even sure if this is possible.
Edited by art3mis
OP. Ok after much trial and error think I figured it out.
Instead of using a single Blast node I am using a Group SOP followed by a Delete node.
Guessing not quite as fast as a Blast but much more flexible.
In the Group SOP I name the group and in the Delete node either choose Delete Selected (to remove primitive geometry) or Delete Non Selected ( to remove particles leaving only primitives)
