Creating a Subway network in VEX
konstantin magnus
I am trying to create a subway network with VEX.
In order to define individual end stations I assigned all points to sectors according to their radial position. Now I am looking for a way to find the bluest/greenest point for each sector.
i@result shows me the best match for all the points, but how can I loop through groups (i.e. "sector_0", "sector_1" and so on) and put all matching points into one array?
vector seek_clr = {0,1,1};
//Finds points with a similar color
int pcloud = pcopen(0, "P", @P, 0.4, 6);
int closecolor[] = pcfind(0, "sector_0", "Cd", seek_clr, 2, 5);
i@result_0 = closecolor[1];
vex_subway_sectors.hipnc
Edited by konstantin magnus
22 minutes ago, konstantin magnus said:
No, thats not it. I think I just need to know how to use point clouds inside for loops.
i dont get it why you are using closestpoint,
you want to find the bluest/greenest color value for each sector and store the bluest/greenest from each sector to a list right ?
colors and positions are interchangeable I hope. thats why pcfind should also be able to look for colors in points.
Maybe I have to
  • iterate through point groups
  • use separate arrays for each sector
  • to finally assign the first entries of each array to one big array
Or is there an easier solution?
I found a solution:
int sectors = detail(0, "sectors", 0);
i[]@result[sectors];
for(int i = 0; i < sectors; i++) {
    string group = s[]@groups[i];
    int closecolor[] = pcfind(0, group, "Cd", seek_clr, 2, 5);
    if(closecolor[1] == @ptnum) setpointgroup(0, "in", @ptnum, 1, "set");
    @result[i] = closecolor[1];
for something like this it´s most probably faster to just interate over the points instead of using pcfind. when you rely on pointcloud functions houdini needs to build a kdtree and in your case it has to rebuild the tree for every "sector". since accessing the tree is fast but building it is relatively slow you loose the advantage of using pointclouds.  this becomes even more apparant when you have a high number of "sectors".
anyway, both versions are attached ...
hth.
petz
vex_subway_sectors1.hipnc
Edited by petz
  • Like 2
