voronoi fracture extrusion issue
benne5
Yea this is the worst part of destruction, getting it to fracturing correctly..
Its created by the inside faces, if you disable create inside faces you wont have the problem, but obviously everyone needs the inside face..
Try use the clean sop, make sure your model has depth (extrude),is watertight and has clean and simple topology.
Always use the voronoi fracture points node and increasing impact radius and volume resolution can help.
The model has to be a certain way for the voronoi node to work correctly, but no one has really outlined these conditions, its kind like rotoscoping - there is no condition you have to meet or rule or objective..you kind of have to beat on it until it works
most annoying part of fx
