MaxGyver Posted December 5, 2016 Share Posted December 5, 2016 Hi, We started using deep rendering and noticed nuke scripts literally explodes if we forgot to check "Exclude from DCM" for each extra passes. My problem is, how do we exclude base components from DCM, like Direct Lighting and Indirect Lighting? There is no Exclude from DCM checkbox for those passes. I tried in H14 and H15. Do I need to manually export those passes in the Extra Image Planes section? Thanks Maxime Quote Link to comment Share on other sites More sharing options...
MaxGyver Posted December 5, 2016 Author Share Posted December 5, 2016 Got an answer from a couple other sources. The trick is to not use the extra components, but use the extra image planes section instead. Quote Link to comment Share on other sites More sharing options...
