Is there a possibility to have @ working inside a vex function?
kgoossens
Is there an possibility to have @ working to create write attributes in a vex function?
Something similar to the following
function void test()
	i@test_attrib = 10;
The reason I want to avoid setattrib is that it is much slower as implementation.
Are there any other idea's? does the *.vcc compiler optimize the setting of attributes?
Cheers
I'm not sure if this helps, but it does work. You can pass the attribute you want to modify to the function.
function void test(int passedAttrib; int passedValue)
        passedAttrib = passedValue;
test(i@test_attrib, 12);
