bonassus Posted December 14, 2016 Share Posted December 14, 2016 I'm having trouble importing .obj files into Houdini. 90% of the time it doesn't work and the file node will say "unable to read file". I have tried checking the mesh in modo and running a mesh cleanup, exporting another .obj. But these files don't import into Houdini either. I have been opening the obj files in Modo and saving them as an alembic which Houdini doesn't have a problem opening. I'm wondering what is wrong here. I'm running an indie license but I don't think there are import restrictions. Does anyone else have this problem? Is there a way to prepare the .obj file for import? thanks Quote Link to comment Share on other sites More sharing options...
Atom Posted December 14, 2016 Share Posted December 14, 2016 There is no need to prepare an OBJ for import. Can you post an example OBJ file that fails to load on your Windows machine? Quote Link to comment Share on other sites More sharing options...
bonassus Posted December 14, 2016 Author Share Posted December 14, 2016 Thanks, The attached file for instance causes an error in the file node. KANGAROOexport.OBJ Quote Link to comment Share on other sites More sharing options...
bonassus Posted December 14, 2016 Author Share Posted December 14, 2016 Yes Windows Quote Link to comment Share on other sites More sharing options...
rbowden Posted December 14, 2016 Share Posted December 14, 2016 Got it to load with Houdini 15.0.416 just fine. Quote Link to comment Share on other sites More sharing options...
bonassus Posted December 14, 2016 Author Share Posted December 14, 2016 rbowden, thanks for trying that. I just tried it with 15.5.480, 15.5.632, and 15.5.673. All with the same result. I don't think it's the version of Houdini that i'm running. Does anyone have an idea how I can get it working properly? Thank you Quote Link to comment Share on other sites More sharing options...
rbowden Posted December 14, 2016 Share Posted December 14, 2016 So humor me on this...I see you have some spaces in your file path (3d models, DOSCH 3D - Animals). Get rid of the spaces in your file name or just move that obj over to a temp directory that doesn't have any spaces in the file path. See if that works...I have had instances where it would error out with spaces in the file path. Quote Link to comment Share on other sites More sharing options...
bonassus Posted December 14, 2016 Author Share Posted December 14, 2016 YES! And, i feel dumb. I moved a few files to the desktop and the they all import. Not all of them have spaces in the file path. But some had some other characters in the path that I guess don't work with Houdini. I just need to clean up my screwy file paths. Thank you very much for your help. Quote Link to comment Share on other sites More sharing options...
