Attribute randomize issue
I just installed Houdini 15.5.683 for Ubuntu 16.04 and I gave a quick look to see how different was from windows version. The first issue that I encountered is with attribute-randomize sop, that gives me a strange error (VEX related). I tried the same setup in windows and everything works smooth! maybe is a ubuntu specific bug? there's someway to fix it, because this sop is essential to me. thanks in advance
ps. I navigated inside the attribute randomize sop to find the actual line error.
Houdini is sensitive to which locale (country specific settings, like whether to use  .   or  , in numbers etc) you use.
If you don't use English locale, the variable fixes a lot of strange errors that only occurs if you have a different locale.
Every time I have installed Houdini in Ubuntu with Swedish locale I had to use the variable to make Houdini work.
One question though.. why is your houdini.env called hodini.env? And otherwise empty? There should already be one in your $home/houdini.15.5 directory.
Maybe that's the problem?
In fact I'm using my own language settings on Ubuntu. I deleted hodini.env ( I didn't saw the type error!) and added LC_ALL = C to the right houdini.env and now everything is fine, no more VEX errors. Thanks a lot Hamp!!
