boyle Posted December 23, 2016 Share Posted December 23, 2016 (edited) Hi guys, I'm trying to learn mantra with some study projects where I take an image from the web and try to recreate it as closely as possible with mantra. (not necessarily geometry-wise but more in terms of look) For this one, I'm trying to achieve that great GI atmosphere from the reference image. Attached is how far I've gotten in mantra, but I don't know how to improve it further to bridge the beauty/quality gap with the reference image. Any tips what direction I should explore? (I'm ignoring the DOF here, as that is obviously easy to do) Much appreciated! Cheers! 2_my_scene_file.hipnc Edited December 23, 2016 by boyle Quote Link to comment Share on other sites More sharing options...
Skybar Posted December 23, 2016 Share Posted December 23, 2016 Don't forget to pull it through comp as well, doing glows and stuff. Quote Link to comment Share on other sites More sharing options...
Sean Lewkiw Posted December 23, 2016 Share Posted December 23, 2016 (edited) Here is something slightly better after an hour or so: facet your wires increase diffuse bounce tweak materials to make more metallic add a env light for the wires only I also did one where I copied a light to every single ball and turned off shadowing on the ball the light was inside. This was looking great but render times were insane. EDIT: for some reason I can't add attachments... going away for the holidays, so this will have to wait until I get back! Edited December 23, 2016 by lewkiw Quote Link to comment Share on other sites More sharing options...
boyle Posted December 23, 2016 Author Share Posted December 23, 2016 (edited) 1 hour ago, Skybar said: Don't forget to pull it through comp as well, doing glows and stuff. Tried doing glows in comp... couldn't get it quite looking better. Mind you I'm still learning the ropes :-) It seems as if there's some global illumination magic sauce in the render. The reference was done with arnold btw. I'm just wondering how to tweak it closer towards that global illumination look while still in houdini (before doing post). Edited December 23, 2016 by boyle Quote Link to comment Share on other sites More sharing options...
boyle Posted December 23, 2016 Author Share Posted December 23, 2016 3 minutes ago, lewkiw said: Here is something slightly better after an hour or so: facet your wires increase diffuse bounce tweak materials to make more metallic add a env light for the wires only I also did one where I copied a light to every single ball and turned off shadowing on the ball the light was inside. This was looking great but render times were insane. cool :-) care to post screenshots/scene files? Quote Link to comment Share on other sites More sharing options...
eetu Posted December 23, 2016 Share Posted December 23, 2016 Took a quickie look as well. Main things I saw were: - there was no GI as your Diffuse Limit in Mantra ROP was 0 - your balls were too rough, they should be shiny and the blur comes from dof - your wires are too thin, they don't form any "mass" And yes, some postprocessing would be a good idea 2_my_scene_file_ee.hipnc 1 Quote Link to comment Share on other sites More sharing options...
boyle Posted December 24, 2016 Author Share Posted December 24, 2016 12 hours ago, eetu said: Took a quickie look as well. Main things I saw were: - there was no GI as your Diffuse Limit in Mantra ROP was 0 - your balls were too rough, they should be shiny and the blur comes from dof - your wires are too thin, they don't form any "mass" And yes, some postprocessing would be a good idea 2_my_scene_file_ee.hipnc great effort on the scene! thanks for the tips! Gonna be testing all of them :-) Quote Link to comment Share on other sites More sharing options...
