Neon Junkyard Posted December 27, 2016 Share Posted December 27, 2016 Similar to the H14 workflow of hitting X on the currently selected node in any vop context to create a visualizer node, I want to do the same but connect the currently selected node to the compute lighting Ce output (or a bind export node set ot Ce but that can throw errors) to quickly visualize the color data of the map I am working on without having to do expensive shader calculations. The visualize node is great when working with Cd in SOPS but does not return the same functionality in shaders This is a default hotkey in arnold for C4D, its like alt+w+v or something. I'm sure there is a way to do this with a python script attached to a hotkey. Any ideas? Quote Link to comment Share on other sites More sharing options...
