Noise Direction question
In an attribute vop, take a 'relative to bounding box' vop and run this through a 'compare' vop set to greater than 0.5. You can plug the result of the 'compare' in to a 'switch' vop with time and negated time as the 2nd and 3rd inputs. Plug that in to the x component of a 'float to vector' vop and plug the result in to the offset of your noise vop. You should see the noise on one half of the sphere moving in positive x and the other half in negative x.
I love these sorts of challenges. :)
Made some rotating uvs so the noise flows around the shape rather than just slides in a wrangle, then drive noise with those uvs.
float t;
matrix3 m = ident();
v@uv = @P;
// set speed
t= @Time*ch('speed');
// get coords that are centered and mirrored on x
@uv = (0.5-relpointbbox(0,@uv));
@uv.x = abs(@uv.x);
// rotate coords around the y axis
rotate(m, t, {0,1,0});
@uv *= m;
mirror_rotating_noise.hip
  • Like 4
