Spray Ignores Colliders?
Atom
Hi All,
I have a working FLIP sim of a water fall that is colliding with my terrain mesh. I have added whitewater to the simulation and when I visualize the GREEN spray particles I can clearly see that they ignore my collision object.
Is there any way to make the GREEN spray collide with the same surface as the WHITE foam?
Thanks for checking. I have two separate DOP networks, one for my initial fluid then the shelf tool built a new whitewater network as well. I did pick the flipobject1, which resides inside AutoDopNetwork, when the whitewater tool asked.
Should my whitewater be inside the AutoDopNetwork instead?
Edited by Atom
@Solitude: No, I do not. On a whim I actually copied my terrain collision nodes from the AutoDopNetwork in to the whitewater_sim but that did not seem to matter.
@rob: I have been busy on other parts of the same sim so I have not had a chance to put together an example of the problem. I am adding a small 0.5, Drag force after Gravity, it seems to be the only way to tame excessive velocity. I also had the velocity smoothing set extremely high at a value of 3. It defaults to 0.1.
I have made so many changes today that I need to conduct a new test and see if the problem still exists.
Edited by Atom
