Load Warnings (All of a sudden)?
Atom
Hi All,
All of a sudden I am getting load warnings when I open scenes.
This is a complete new scene that I created today. I saved the HIP file then when I reopen it I see the load warnings. I also see warnings on older HIP files that previously did not have any load warnings.
What does this mean?
Why did it start happening?
Does anyone know...
this has happened to me as well for a few times. not sure what exactly does it mean and I have never found anything broken or missing in the scene. would be nice though if somebody offered an explanation :)
Edited by davpe
The root of the cause is that the scene files has defined those parameters in the saved file as part of the node from that saved version, and it can not reconcile the difference.
This usually happens when your scene files were created in another version of Houdini, or also when an HDA/OTL is missing or of a different version either higher or lower
You can usually look at those parameters it is listing out and see where each node is being affected. When you have a lot of nodes it becomes incredible painful, but a few nodes it's worthwhile to track down and make sure you didn't break anything.
Assuming your Houdini version or your HDA versions don't change again, you should only see this on the first load with these new changes.
I would get a series of prairie dog heads from different desk, when I would update the studio version of Houdini or I changed an otl and say removed a parameter that everyone had. Usually it's nothing to panic about, unless you are going from H12 to h15.5 when major changes happen say grabbing a file from odforce, or say you break the studio IMPORT node. ;)
