Atom Posted January 26, 2017 Share Posted January 26, 2017 (edited) Hi All, I came across something strange, Houdini won't read an .obj file. The file comes up fine in Blender. It also worked fine on my other machine running Houdini Indie. I copied the file to my Apprentice machine, running H15.5.673 and the File node errors out? Can someone try this .OBJ file on their system if you have the time? Thanks palm_trio.obj Edited January 27, 2017 by Atom Quote Link to comment Share on other sites More sharing options...
dimovfx Posted January 26, 2017 Share Posted January 26, 2017 Works just fine for me. H15.5.717 I remember there was other thread with the same complaint, but don't remember what was the solution if there was any. Quote Link to comment Share on other sites More sharing options...
Atom Posted January 26, 2017 Author Share Posted January 26, 2017 Thanks for testing. I guess it is upgrade day. I'll try the 717 build. Quote Link to comment Share on other sites More sharing options...
Atom Posted January 26, 2017 Author Share Posted January 26, 2017 (edited) Hmm...same error after upgrading to H15.5.717. The main difference between my two machines is the one with Windows 7 will read the OBJ and the Windows 10 will not. Does Houdini have a text log that will explain in more detail what the error is? Edited January 26, 2017 by Atom Quote Link to comment Share on other sites More sharing options...
Mandrake0 Posted January 26, 2017 Share Posted January 26, 2017 can you convert the file with gwavefront? when i'm correct houdini uses this small program to open the obj files or even create obj's. example: gwavefront fileIn.obj fileOut.bgeo it's in the houdini bin folder. 1 Quote Link to comment Share on other sites More sharing options...
Atom Posted January 26, 2017 Author Share Posted January 26, 2017 (edited) I tried your test and it worked. I can manually convert .obj to a .bgeo and load the .bgeo using the gwavefront.exe. So the problem must be an error in the File node itself. "I told you not to let the intern write code..." Here is the default cube as exported from Blender which fails to load using the File node. # Blender v2.78 (sub 0) OBJ File: '' # www.blender.org mtllib cube.mtl o Cube v 1.000000 -1.000000 -1.000000 v 1.000000 -1.000000 1.000000 v -1.000000 -1.000000 1.000000 v -1.000000 -1.000000 -1.000000 v 1.000000 1.000000 -0.999999 v 0.999999 1.000000 1.000001 v -1.000000 1.000000 1.000000 v -1.000000 1.000000 -1.000000 vn 0.0000 -1.0000 0.0000 vn 0.0000 1.0000 0.0000 vn 1.0000 0.0000 0.0000 vn -0.0000 -0.0000 1.0000 vn -1.0000 -0.0000 -0.0000 vn 0.0000 0.0000 -1.0000 g Cube_Cube_Material usemtl Material s off f 1//1 2//1 3//1 4//1 f 5//2 8//2 7//2 6//2 f 1//3 5//3 6//3 2//3 f 2//4 6//4 7//4 3//4 f 3//5 7//5 8//5 4//5 f 5//6 1//6 4//6 8//6 cube.obj Edited January 26, 2017 by Atom Quote Link to comment Share on other sites More sharing options...
Mandrake0 Posted January 26, 2017 Share Posted January 26, 2017 on my side it works. the simplest cube obj would be: # test v 1.000000 -1.000000 -1.000000 v 1.000000 -1.000000 1.000000 v -1.000000 -1.000000 1.000000 v -1.000000 -1.000000 -1.000000 v 1.000000 1.000000 -0.999999 v 0.999999 1.000000 1.000001 v -1.000000 1.000000 1.000000 v -1.000000 1.000000 -1.000000 g f 1 2 3 4 f 5 8 7 6 f 1 5 6 2 f 2 6 7 3 f 3 7 8 4 f 5 1 4 8 when that doesn't work then it's a build error. Quote Link to comment Share on other sites More sharing options...
f1480187 Posted January 27, 2017 Share Posted January 27, 2017 Probably a filepath problem. It cannot find the file on disk. If you try any random non-existent geo path you will see same message. Make sure if the file exists on Windows 10 machine there, then try to load the file from different places and finally submit a bug. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted January 27, 2017 Share Posted January 27, 2017 Looks like the $HOME variable is set wrongly. Try the file path from $HIP or without a variable. Quote Link to comment Share on other sites More sharing options...
Atom Posted January 27, 2017 Author Share Posted January 27, 2017 (edited) Thanks everyone, I got some help from SESI support. It is related to having an invalid path in your Houdini.env file. At some point I considered loading Redshift on my machine and altered the PATH to point to the Redshift folder. But now that folder does not exists. My guess is that when the File node tries to load something it reviews the environment path looking for a shortcut to pathing. However, when it finds the PATH variable, it is assuming the path is valid and not checking to see it if actually exists. It then constructs a path that is invalid and the file load fails. I guess I would consider this a bug. The File sop should be more robust and not be easily clobbered by an invalid environment path when the full path is provided in the text field of the node. Hopefully it will be fixed, but the work around is to simply review the pathing in your Houdini.env file and make sure all paths still exists if you run into this problem. Edited January 27, 2017 by Atom 3 Quote Link to comment Share on other sites More sharing options...
Guest tar Posted January 27, 2017 Share Posted January 27, 2017 On 30/11/2016 at 4:56 PM, art3mis said: Feedback from sesi finally figured this out My houdini.env was at fault Missing C:/Program Files/Side Effects Software/Houdini 15.5.632/bin; in my PATH variable Funny; that's exactly the same error that art3mis got a few months ago, and, both of you are programmers Quote Link to comment Share on other sites More sharing options...
