How to have the rigid body solver handle each primitive of a merge ?
AntoineSfx
I have  a geometry node; inside are several copy SOP with boxes instantiated on a grid. All the copy SOP are merged into an output node.
What do I need to have each primitive handled separately by the solver ? ( The RBD Object creates one object with all the primitives in a fixed position with respect to each others)
20 minutes ago, Skybar said:
Take a look at the shelftool "RBD Point Object" and then "RBD Packed Object" in the popup.
Thanks.
Actually the geometry is final inside my geometry node, I don't need it replicated; the tool I was looking for was RBD Fractured object / Packed objects
6 minutes ago, AntoineSfx said:
Thanks.
No but the workflow from that shelftool was the same so you could take notes from it.
