6ril Posted February 7, 2017 Share Posted February 7, 2017 Hey, I need to render with objectsID AOV, with Arnold, and I'm failing miserably :/ In the AOVs liste, there's an ID aov, but can't make it work. So I looked into Cryptomatte since I'm using ALshaders. I can't find info about how to use it, just a tutorial for maya on anderslanglands.com, where it seems simple (just enable crypto_object and crypto_material). But there's no such things in Houdini :/ All I can see about cryptomatte is in the shader nodes, there's an AOV tab with confusing things... Can you help ? Quote Link to comment Share on other sites More sharing options...
6ril Posted February 7, 2017 Author Share Posted February 7, 2017 ok, I've simply typed crypto_material in the arnold ROP in AOV name, and now I get an AOV with some flat colors. but I guess I still need to separate them into multiple aovs for use in comp with cryptomatte plugin ???? Quote Link to comment Share on other sites More sharing options...
6ril Posted February 9, 2017 Author Share Posted February 9, 2017 nevermind then... Quote Link to comment Share on other sites More sharing options...
