Bakiki Posted February 16, 2017 Share Posted February 16, 2017 Hi Could anyone tell me why these box instances do not appear until frame 94. Thanks for your help instance attempt.hipnc Quote Link to comment Share on other sites More sharing options...
foxel Posted February 16, 2017 Share Posted February 16, 2017 The object merge node inside your instances had a bad parameter reference. A bit weird but might have had something to do with you locking the parameter or messing with it in some other way instance attempt_fix.hipnc Quote Link to comment Share on other sites More sharing options...
Bakiki Posted February 16, 2017 Author Share Posted February 16, 2017 32 minutes ago, foxel said: The object merge node inside your instances had a bad parameter reference. A bit weird but might have had something to do with you locking the parameter or messing with it in some other way Thanks for the reply. I have tried in different sessions and I have the same issue. Even if I replace the object merge with a fresh instance I have the same problem....? instance attempt_fix.hipnc Quote Link to comment Share on other sites More sharing options...
foxel Posted February 17, 2017 Share Posted February 17, 2017 4 hours ago, Bakiki said: 4 hours ago, foxel said: The object merge node inside your instances had a bad parameter reference. A bit weird but might have had something to do with you locking the parameter or messing with it in some other way Thanks for the reply. I have tried in different sessions and I have the same issue. Even if I replace the object merge with a fresh instance I have the same problem....? instance attempt_fix.hipnc Frank, I'm not having that issue. Is this what you are doing? 1. Go inside instance1 network 2. Delete old Object Merge, create a new Object Merge 3. In Object 1 field of the object merge properties, select /obj/grid_object1 Quote Link to comment Share on other sites More sharing options...
Bakiki Posted February 18, 2017 Author Share Posted February 18, 2017 On 17/02/2017 at 1:20 AM, foxel said: Frank, I'm not having that issue. Is this what you are doing? 1. Go inside instance1 network 2. Delete old Object Merge, create a new Object Merge 3. In Object 1 field of the object merge properties, select /obj/grid_object1 Yes, I have implemented this method and still the same problem. Now, I'm really puzzled that you are not seeing the same behaviour. My problem is that the box instances don't start appearing on the grid points until frame 94. Ok, I've solved the issue in case anyone has this problem. Make sure when the object merge is created, that the frame marker is on 1 and not anywhere else on the timeline... Thanks for all the replies.. Quote Link to comment Share on other sites More sharing options...
