Unique fracture on each copy?
prekabreki
I was wondering if anybody had a simple-ish way to have an individual voronoi fracture for each copy of a geometry.
Here's a picture of my current setup and I tried copy stamping a random seed on the scatter, which of course didn't work.
I also thought about using a for-each loop but had no luck really.
I've attached my current scene file if anybody wants to take a look.
Here are pictures of my current setup as well.
http://imgur.com/a/05w1S
http://imgur.com/a/iQFu6
FRA_FENCE.hiplc
You want each "plank" to have a different voronoi? First, shouldn't you consider using the new shatter tools in H16? They are almost tailor made for this situation! Second, answering your question, are the pieces separated in some manner? I suppose they are. If that's the case you can put a connectivity sop and then a for loop subnet. Inside the subnet you can vary any parameter based on the iteration number. That way each piece will be different
I don't have H16 right now, so I can't open your file
I'm still on h15.5 since 16 was buggy for me so I can't open ur file.
You can do the modeling, then use a connectivitySOP to create an attribute for each not connected prim.
Do a foreach subnet for each class and use the stamp inside that to drive the seed.
See if you can open this file I made.
Fracture_Foreach.hip
