Procedural Sawdust
chrisdunham95
Hey guys, working on creating some procedural sawdust for a student short - so far im kind of happy with what im getting but my method is quite heavy which means takes upto a day to sim it all out and still cant get it looking perfectly
- I take 5 peices of geo scatter it randomly with copy sop - then dynamically drop it onto the enviro (using packed primatives)
- Take that geo - use as collision - drop another layer of copied sawdust ontop again using RBD packed object
- i then create a final layer of sawdust and drop that onto the terrain and previous layers - As ive said this method is very heavy as i need as much geo as possible to get the 'sawdust' look -
- My main question is - is their away to dynamically drop 1,000,000 cubes onto enviro geo then take the cubes and copy my sawdust geo onto that? - The main reason for the dynamic drop is to get the placement to look natural / no intersections etc.
Any thoughts or ideas on anyone elses approach or a technique i could add to what i have to create more control? - i had thought about creating a attribute which drove the orientation of the peices but even then id get intersections which other sawdust geo aswell as the environment
have you tried to use a proxy geo for collisions? you can then very easily replace them with high res geo. Then you should be have to skip the layers and drop them all at once ? maybe ?
1 hour ago, benne5 said:
You might want to consider scattering/painting points on your environment and then instancing or copying stamaping the sawdust bit to the points.  They copystamping can include variables for rotation, scale, etc.
oh I thought Chris wanted some animation of the sawdust falling... But if it just to settle a pile of dust, INSTANCING (more efficient then stamping) would be the easiest way.
but.. self intersections.... might not be such a problem tho (depend on the distance to cam).
 Yeah this is what im currently doing - very close to cam at times but defocus will be used thanks tho guys
