forEach vs forEach subnet problem
Fyre
Trying to use an attribute to drive random values in a carve. Works in subnet foreach but not new for each.
forLoopCarveProblem.hip
As far as I'm aware the carve can't use $PR etc directly so I'm using the prim function in a forEach loop. Just a bit confused as to whats going on.
If I create the setup in a "new" foreach loop I'm getting the same U value for each curve, but If I create the carve and use the prim attribute in a subnet for each loop it works fine. Now I'm guessing theres something different in how these two operate. AforLoopCarveProblem.hips I can't use PR I'm using 0 in the loop, and the subnet (as far as I can tell) culls each primitive into its own geometry?? So this works?
But the new foreach loop will just take the value of primitive 0 and apply it to every iteration?
Or am I way of base here, Confused.
You gotta use the Create Meta Import Node
and use the iteration number. Then you can use this on your carve
rand(detail("../foreach_begin1_metadata1/", "iteration", 0))
Edited by Sepu
Thanks very much, I got it to work per your advice, however its all contained within the carve now. This is using iteration as the attribute for each primitive, which is fine, but what if I wanted this value to be driven by 'dist' attribute, created outside the for loop and call it in? Like in my example scene?
i.e. for each 'iteration' use 'dist'
cheers
As David mention you do not have to use for each for this, but if you want to know
You can also do this on the carve then you will get the same as your old for each.
fit01(rand(detail("../foreach_begin1_metadata1/", "iteration", 0)),0,.5)
or you could also do it with a couple of wrangle to get control, like in the hipnc
forLoopCarveProblem02.hipnc
