Hayden Posted March 23, 2017 Share Posted March 23, 2017 I Have stacks of plates and bowls that i made with a copy node on one original model of each type of plate or bowl rather than importing each model multiple times. I want each object to be able to fall and smash independently which i am struggling to work out. When i make the stack a RBD Glued Object it either all moves and smashes the exact same way like they are being read as one whole piece rather than individual plates/bowls or they move individually but the glue errors saying "making objects from different solvers mutual affectors" so they cant smash. Sorry if this is a basic question i am new to Houdini, any help would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
Atom Posted March 23, 2017 Share Posted March 23, 2017 One thing I notice right off the bat is that all your copies are fractured using the same exact pattern. I would start there. You need to find a way for each piece in the cabinet to have a different Voronoi pattern. Can you share a small version of your scene that demonstrates the problem? 1 Quote Link to comment Share on other sites More sharing options...
