Break constraints problem setting attributes at sop level
SphericalCow
Hello OF,
I have a small issue which I hope you can help with...
I am creating attributes at SOP level to control the breaking of constraints in a SOP Solver in DOP's using the
following VEX code in an attribute wrangle connected to 'relationship geometry' of the SOP solver.
if (s@constraint_name == "pin_between"){
    if ((f@torque>@break_torque||@angle>@break_angle||f@force>@break_force)){
        s@constraint_name = "pin_broken";
        i@breakframe = @Frame;
My issue is that when I disable one of these attributes at the SOP level, the sop solver seems to interpret it at a value of 0, and
the objects constraint will be completely removed on collision.
Is there a better function to use than 'or' in this situation? An 'if else' seems more appropriate, but I am unsure of the syntax of
that in this situation within VEX.
Any help would be greatly appreciated.
Many thanks in advance.
  • 1 year later...
Hello i'm trying to break my hard or glue constraints but it doesn't work
if (@constraint_name == "hard"){
  if (f@torque > 7500 || f@angle > 10 ){
      s@constraint_name = "hard_broken";
hard constraint use force only.
Try this
if (@constraint_name == "hard" && length(@force)>1000){
or I use this one
if(@constraint_name == "hard"&& length(@force)>1000)
	removeprim(0,@primnum,0);
Glue constraint used strength attribute to brake
Edited by tamagochy
3 hours ago, johanfx said:
none of those are working. could please send me a set up file. so i could see it please!!
Strange it doesn’t work... maybe it is breaking and deleting the primitive correctly, but reimporting it from sop afterward ?
To avoid that, check if your constraint network in SOP context (outside DOP, where the Geometry Source of you Constraint Network is pointing to) is « animated » or considered time dependent. In this case, you have to manually set Overwrite with SOP to 0 on the Constraint Network DOP node, and delete the default expression inside this parameter.
In short, it will import your network once at the start, and then relationship will live only inside DOP without being updated from SOP.
And check that your display flags are set correctly to your last node in SOP Solver, sometimes i make this simple mistake :-)
Edited by StepbyStepVFX
