Graphing bitcoin in Houdini with python
The Batchman
Hey guys,
I'm very interested in anything with crypto currencies like Bitcoin. I've coded something together that grabs the current Bitcoin price from the web and throws it into Houdini as a 3d text.
I've also managed to get the Bitcoin price history and graph it inside Houdini.
Don't know tho whom it may be useful but look around or maybe even improve it. Maybe it might create new ideas.
Python code and example available in the attachment or at github.
The Batchman
Bitcoin.hipnc
On 3/30/2017 at 4:06 PM, 3dome said:
just downloaded it out of curiosity. getting an error on the python sop with line 1 "import requests"
it cant find that module. using H16
cheers
Oh dear! I thought python came with the requests library by default.
If you are on a Linux machine you can open up a terminal and enter the command:
pip install requests
If you are on a Mac or Windows machine I don't know how to get it to be honest. However I think this is a good start if you need this to work.
Hope you get it working!
Note sure if totally related, but did you know that you can use http:// and ftp:// URI's directly in file fields in Houdini?  For example, you can refer to an image fetched by an http request directly in COPs, textures, backgrounds or wherever you encounter image paths.
PS. You can add your own -- see the FS_ReaderHelper/etc docs
  • 3 weeks later...
That is really cool! Didn't know that was possible with files too. Might be helpful one day.
I've noticed though that HTTPS is not supported, while HTTP is. I've tested this in my python script and also just checked this with a COP File node. Doesn't want to import anything HTTPS, the error generated from the python shell is the following.
/usr/local/lib/python2.7/dist-packages/requests/packages/urllib3/util/ssl_.py:334: SNIMissingWarning: An HTTPS request has been made, but the SNI (Subject Name Indication) extension to TLS is not available on this platform. This may cause the server to present an incorrect TLS certificate, which can cause validation failures. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.io/en/latest/advanced-usage.html
#ssl-warnings
SNIMissingWarning
/usr/local/lib/python2.7/dist-packages/requests/packages/urllib3/util/ssl_.py:132: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.io/en/latest/advanced-usage.html#ssl-warnings
Interesting, I didn't know that. Perhaps SideFX would have some insight if you wanted to solve this puzzle.
FWIW, we have implemented our own URI handlers pointed at our asset system using that class. It can be very intuitive if done right.
