Brick wall procedurally (circular and flat)
anicg
Here is lazy procedural approach. Slice by planes into rows, resample cross-sections by approximate brick length and turn pscales on. Copy bricks to points and finally make use of new boolean. Shatter mode will give you mortar, I used another method, to allow later remeshing. Try to randomize cross-sections a bit, so, it won't resample into almost same curves (brickwork won't look lame).
bricker.hipnc
Edited by f1480187
  • Like 7
