Editing Curve Points In Otl
Hi there,
Is there a way to provide top-level curve editing cability for an otl (digital asset) ? I have a curve sop in my otl. I want users of my otl to be able to move the points in the curve without having to go inside. Is there a built-in way of setting this up, or do I have to do something ad hoc?
Thanks!
Christine Smith
Northrop Grumman
Engineering Visualizatin Resource
Hi there,
Thanks!
Christine Smith
Northrop Grumman
19351[/snapback]
hey
take a look at this link
http://odforce.net/forum/index.php?showtopic=1787
its mentions something similiar to what u wanna do :-)
dont know if it will work, but its worth checkin out
aracid :blink:
Hi Christine,
There is no built-in way, unfortunately. Here's a similar thread discussing about reselecting geometry in a HDA (Houdini Digital Asset) and in it, Jeff Wagner provided instructions on how to reselect by editing the dialog script of the HDA.
Personally, I tried it & it works though it took a couple of attempts before getting it to work the way I want. I don't know how well it'll work for editing a curve but it's worth a try if you are up for it.
Is this an Object level or SOP level HDA?
Cheers!
steven
Hi Christine,
Yeah, I read that one, but I have no idea how I can use that to do what I want to do. Is there any documentation on that language? It doesn't look like hscript.
19354[/snapback]
With Jeff's first or second post, he attached a file called "sop_bindselector.txt" which contains the instructions.
Cheers!
steven
Another good tip with this type of thing is to provide a button that opens up a viewport floating window with the sop as the focus.
use something like this
pane -F -m viewer -h /obj/model/curve1
The downside being the asset will have to be unlocked for it to work.
I found what I was looking for! :)
In the Handles section of the Operator Type Properties, I created a "Curve Point Options" handle. I created a parameter for my digital asset by dragging my coordinates from my curve sop into the Operator Type Properties window. Then, I pointed to this parameter in the Handles area using the arrow next to "pointlist".
I didn't know what I was doing or if it was going to work, but it works! When I hit Enter, I see the curve points and can manipulate them as if I were in the SOP editor.
Thanks for your input,
Christine
For that, there's actually a slightly easier way since you're using a SOP OTL.
- Open up your Type Properties dialog
- Dive down to your curve sop
- Hit enter with your mouse in the viewer to show the handle
- Right-click on the handle and choose Export Handle to Type Properties.
This automatically export the required parameters and set everything up for you in the Handle tab. You can further edit the results of course.
Excellent! I will definitely make good use of this.
19361[/snapback]
  • 7 years later...
I have an additional dilema in that I have two curves to edit and so I have created two handles on the otl. I now need to switch focus between them so I can edit each in turn
any ideas anyone?
many thanks
Edited by glassman3d
