Dynamic RBD - Houdini to Unreal
JayAims
Would anyone know how to pre-fracture geometry in houdini, bring it into unreal engine and have it be dynamic (responsive to real-time collisions)?
I know unreal has a way to do it and be dynamic, but Im wanting to be able to art direct from houdini for the area where my collision will happen in the level.
I have already tried pre-fracturing with voronoi and exporting as alembic and fbx but no dice. Just wanted to see if anyone had a solution to this.
Any ideas?
Hi James,
It is possible. Each fractured piece has to be in it's own geometry container so that when you export it as an fbx it creates the necessary hierarchy.  You can then use "import fbx chunks" on the destruction mesh to create the depth 1 pieces.
Mike
