a question for making custom normal on Point
shinsso
Guide Tangent Space didn't compute vectors that necessary looking down, which IMO contradicts with "make N which is head to down along edges". If you won't be happy with GTS output on the real geometry: at first, decide the unique characteristic the target vector will have. Does it points to point's neighbour with least/largest ptnum? Does it points along edge closest to {0, -1, 0} direction? The idea behind choosing one edge over another. That will be a big part of the answer.
Edited by f1480187
Yes. you're right f1480187.
When I applied it to my real geometry, it was not correct.
So, I just tried to use Sort node.
I sorted points using 'Along Vector' {0, -1, 0}, then I made normal with vop ; I used subtract between position of ptnum and ptnum-1.
It's not exactly correct, but it is pretty close to what I want, cuz I just needed velocity for popnet.
Thank you for your advised f1480187!! :D:D:D
Here the snippet which allow to select such down edge more reliably. It works better than height sorting method in cases, where short edges with better "down ratio" may have greater Y than long edges.
// Point wrangle.
int nbs[] = neighbours(0, @ptnum);
// Find edge best aligned with negative Y.
float dots[];
foreach (int nb; nbs)
    vector pos = point(0, "P", nb);
    vector dir = normalize(pos - @P);
    append(dots, dot(dir, {0, -1, 0}));
int best_nb = nbs[find(dots, max(dots))];
vector best_edge = point(0, "P", best_nb) - @P;
v@dir = normalize(best_edge);
down_edge.hipnc
