Hey Guys,
I am trying to get POPs to emit a finite element.
I have a simple setup where I am birthing a particle every 50 frames and having this fed into DOPs where the finite element solver takes over.
The problem is I cant seem to source more then 1 instance of the object into Dops.
I have attached a scene file I hope someone can help.
Thanks,
Clive
Balls_Test_Fem.hipnc
Hey Guys,
Thanks for this I will take a look. I did end up finding a solution to my problem but without the need for POPs.
I ended up using a single expression with a modulo function within the creation frame parameter to source my object on specific frames.
Here is the the expression I used, if anyone is interested. if($F%20==0,$F,-1)
This worked pretty nicely but I am still interested in using POPs as an emitter source to birth the instanced FEM object. I am going to explore this further when I have the time.
If I figure this out I will post a Hip file here.
Thanks,
Clive
Edited by CliveLlewellyn
