Tiles or shingles tangential to sphere surface
art3mis
Using a scatter and new copytopoints SOP to try and wrap tiles or shingles around a sphere.
The issue is that the tiles all have the same orientation. (see attached) They need to wrap the surface.
I've tried adding a new points SOP with Class = points and Attribute = Normal with the VEXpression
 self + value
and can change the direction of the tiles but only globally.
Can anyone have a look at the attached .hip and tell me what I am missing?
tiles_wrap_sphere.hiplc
Edited by art3mis
after the sphere simply do attribwrangle, @N = @N;
then scatter, then copytopoints
(or in terms of the new Points, just self instead of + value, then scatter, then copytopoints)
Edited by Noobini
Thanks! Tried both suggestions but...nope. Again orientation is changed but all tiles have the same orientation. Something missing I think...
I think I need to modify self + value in my Points sop so that the normals are all tangential to the sphere surface.
Edited by art3mis
01) your sphere is still a primitive, I've set it to polygon
02) your 'plane' must be Z facing...because Z is the axis that is used to line up with the normal....if it is a ''pointy' object...like the pig head...naturally you want the top of the head to line up with the normal...so in the file I included the pig head turned 90deg. Plug this in and see...much easier than to see with a plane.
tiles_aligned.hipnc
tiles_aligned_randomrot.hipnc
Edited by Noobini
