Noobini Posted June 23, 2017 Share Posted June 23, 2017 hey all, I might start this thread and ppl can keep adding presets to it. Requirements: H16 I've done Spherify and Morph using the new Point SOP as can be seen here: and here: Now next step was to create presets so I've done that to my file in: C:\Program Files\Side Effects Software\Houdini 16.0.633\houdini\VEXpressions.txt File is attached...but you don't have to use it...you can edit it manually if you prefer...so navigate to your file (do a backup first), and add near the bottom: # # Attribute Expression # attribexpression/snippet Pass Through self attribexpression/snippet Constant Value value attribexpression/snippet Multiply by Constant Value self * value attribexpression/snippet Add Constant Value self + value attribexpression/snippet Random rand(@elemnum) attribexpression/snippet Random Scale of Value value * float(rand(@elemnum)) attribexpression/snippet Random Offset of Value value + rand(@elemnum) attribexpression/snippet Second Input's Position @opinput1_P attribexpression/snippet Flatten Vector set(self.x, 0, self.z) attribexpression/snippet Uniform Parameter on Polyline vertexprimindex(0, @vtxnum) / (primvertexcount(0, @primnum) - 1.0) attribexpression/snippet Subtract Center of First Input self - getbbox_center(0) attribexpression/snippet Spherify P lerp(self,(normalize(self - getbbox_center(0)) * ch("radius")) + getbbox_center(0),ch("Amt")) attribexpression/snippet Spherify N @P - getbbox_center(0) attribexpression/snippet Morph to 2nd Input lerp(self, point(1,"P",@ptnum),ch("Amt")) You can see the ones I added in bold called Spherify P, Spherify N and Morph to 2nd Input...so next time you use your Point SOP you'll have these presets. (the Spherify P and N logically go together in one Point SOP) VEXpressions.txt 6 Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 23, 2017 Author Share Posted June 23, 2017 (edited) Flat Bottom: attribexpression/snippet Flat Bottom set(self.x, clamp(self.y, ch("Level") + getbbox_min(0).y, getbbox_max(0).y), self.z) Edited June 23, 2017 by Noobini 1 Quote Link to comment Share on other sites More sharing options...
f1480187 Posted June 23, 2017 Share Posted June 23, 2017 You can add the file as user override in your $HOME/houdiniX.X/VEXpressions.txt You need only have your own snippets there (bold part of original post), and can remove default ones, they will be loaded from $HH. 1 Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 23, 2017 Author Share Posted June 23, 2017 (edited) where is this $HOME thing ?...still not very confident with these variables...so i read a post on SESI and some guy had so much troubles trying out this file in umpteenth locations...so i thought...screw it...i'll edit the file directly instead of 'appending' https://www.sidefx.com/forum/topic/50259/ Edited June 23, 2017 by Noobini Quote Link to comment Share on other sites More sharing options...
f1480187 Posted June 23, 2017 Share Posted June 23, 2017 On Windows example locations are: $HOME C:\Users\username\Documents $HFS C:\Program Files\Side Effects Software\Houdini 16.0.633 $HH C:\Program Files\Side Effects Software\Houdini 16.0.633\houdini "$HOME/houdiniX.X/VEXpressions.txt" is a portable way to say something like "C:\Users\JohnDoe\Documents\houdini16.0\VEXpressions.txt". You can override stuff from $HH here. 1 Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 23, 2017 Author Share Posted June 23, 2017 ok, my C:\Users\xxx\Documents\houdini16.0\VEXpressions.txt works straightaway, so only include user/custom snippets in here otherwise, it will double up. (note: Documents is just an alias of My Documents) # Lines starting with # are comments and ignored # # Each entry starts with no indentation and gives the key used # by the menu callback. By convention, this is nodename/parmname. # Multiply keys can be given for the same entry. # # The next line gives the name of the expression. Its indentation # level is then used for the remainder of the text. All the # code until the next parameter are appended together to make # the snippet. All preceeding indentation is removed. # Note that tabs == 8 is assumed. # # Attribute Expression # attribexpression/snippet Spherify P lerp(self,(normalize(self - getbbox_center(0)) * ch("radius")) + getbbox_center(0),ch("Amt")) attribexpression/snippet Spherify N @P - getbbox_center(0) attribexpression/snippet Morph to 2nd Input lerp(self, point(1,"P",@ptnum),ch("Amt")) attribexpression/snippet Flat Bottom set(self.x, clamp(self.y, ch("Level") + getbbox_min(0).y, getbbox_max(0).y), self.z) ...and btw, your custom ones will appear BEFORE the default ones... Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 25, 2017 Author Share Posted June 25, 2017 (edited) a couple of common ones, Archimedean Spiral and Helix...no need for any 'plugins'. (note the names suggest usage on lines...by default a line is created straight up in the Y axis...so if you want to apply to a grid...then simply align your grid to the Y axis) attribexpression/snippet Line - Archimedean Spiral set(ch("radius")*relbbox(@P).y*cos(relbbox(@P).y*ch("turns")*2*$PI),ch("radius")*relbbox(@P).y*sin(relbbox(@P).y*ch("turns")*2*$PI),self.z) attribexpression/snippet Line - Helix set(chramp("width",relbbox(@P).y)*ch("radius")*sin(relbbox(@P).y*2*$PI*ch("turns")),ch("height")*relbbox(@P).y,chramp("width",relbbox(@P).y)*ch("radius")*cos(relbbox(@P).y*2*$PI*ch("turns"))) Does anyone know how to 'arrange' so that the custom ones appear AFTER the default ones...cuz I actually prefer to see the defaults on top...? Edited January 3, 2018 by Noobini 1 Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 26, 2017 Author Share Posted June 26, 2017 (edited) I must be so dumb that I can't properly use the default Taper... So I wrote my own VEXpressions: attribexpression/snippet Taper X set(self.x,self.y*chramp("profile",relbbox(@P).x)*ch("mult"),self.z*chramp("profile",relbbox(@P).x)*ch("mult")) attribexpression/snippet Taper Y set(self.x*chramp("profile",relbbox(@P).y)*ch("mult"),self.y,self.z*chramp("profile",relbbox(@P).y)*ch("mult")) attribexpression/snippet Taper Z set(self.x*chramp("profile",relbbox(@P).z)*ch("mult"),self.y*chramp("profile",relbbox(@P).z)*ch("mult"),self.z) Why can't it be this simple to use ? Edited June 26, 2017 by Noobini EDIT: added 'mult' channel as a Multiplier, after you created the Parameters, set the 'mult' to 1 (as default) 1 Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 28, 2017 Author Share Posted June 28, 2017 (edited) Droop: (move over squab...here comes Piggyphant) attribexpression/snippet Droop set(@P.x,@P.y - ch("droop")*chramp("effect",fit(length(set(@P.x,0,@P.z)),0,getbbox_size(0),0,1)),@P.z) Edited January 3, 2018 by Noobini Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 28, 2017 Author Share Posted June 28, 2017 Melt: attribexpression/snippet Melt set(@P.x*ch("melt")*chramp("effect",relbbox(@P).y)+@P.x,clamp(@P.y - ch("melt"),getbbox_min(0).y,getbbox_max(0).y),@P.z*ch("melt")*chramp("effect",relbbox(@P).y)+@P.z) 2 Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 29, 2017 Author Share Posted June 29, 2017 (edited) Collision Deform: - 1st input - Geo to deform - 2nd input - Collider attribexpression/snippet Collision Deform length(@P-point(1,"P",nearpoint(1, @P)))<ch("dist")?lerp(@P,@P+@N,ch("deform")*chramp("lip",fit(length(@P-point(1,"P",nearpoint(1,@P))),0,1,0,1))*(1-length(@P-point(1,"P",nearpoint(1,@P))))):@P CheapAssCollisionDeform.hipnc Edited June 29, 2017 by Noobini added sample scene 3 Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 29, 2017 Author Share Posted June 29, 2017 so this is how I would do the Collision Deform with wrangle...yes, much more legible and don't have to repeatedly get the distance/nearest pt...question is: is it possible at all to declare/use 'variables' (like dist) in VEXpressions ? (are VEXpressions/snippets strictly one line jobs ?) int nearestptnum = nearpoint(1, @P); // get nearest pt number vector nearestpt = point(1, "P", nearestptnum); // get nearest pt float dist = length(@P - nearestpt); // distance to nearest pt of collider @P = dist < ch("range") ? lerp(@P,@P+@N, ch("deform")*chramp("lip",fit(dist,0,1,0,1))*(1-dist)) : @P; Quote Link to comment Share on other sites More sharing options...
f1480187 Posted June 29, 2017 Share Posted June 29, 2017 (edited) I guess, Attribute Expressions assumed to be simple and artist-friendly. You can use just a Wrangle for complex code, obviously. It's the most straightforward way. It also supports VEXpressions.txt file. Since it is VEX, you can use semicolon to split instructions. It is possible to place almost everything in a single line. You can't hack everything with it: for example, modifying other attributes will output an error due to Python scripted restriction on exported bindings list (which attributes can be modified). Why this is forced to be selected attribute and not left to the default asterisk? Strange. Here is the hack. Start with "bypass" statement. It will allow for @P to stay unmodified and terminate initial assignment. Then add any statements you want. Check Generated Code tab to see the final snippet. It's all just a dirty hack, but it will work. So you don't need to call same expensive geometry traverse function again and again. // Attribute expression. @P; float x = @P.x + 1; @P = set(x, @P.y, @P.z) // Generated Code. v@P = @P; float x = @P.x + 1; @P = set(x, @P.y, @P.z); // Same, but split statements by newlines. v@P = @P; float x = @P.x + 1; @P = set(x, @P.y, @P.z); Edited June 29, 2017 by f1480187 1 Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 29, 2017 Author Share Posted June 29, 2017 wow wee...I thought I'd keep it simple...yesterday I tested by prefixing a working one liner with int i=1;...surely that would work....but nooooooo it has to be @P first......thanks f1480187 !!! ok, let's hope I can do some cleanups and make these less cryptic... Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 30, 2017 Author Share Posted June 30, 2017 ok here's the Collision Deform in a more legible format if you you go ALT+E to go into Expression Editor mode: attribexpression/snippet Collision Deform @P; int nearestptid = nearpoint(1,@P); vector nearestpt = point(1,"P",nearestptid); float dist=length(@P-nearestpt); @P = dist<ch("range")?lerp(@P,@P+@N,ch("deform")*chramp("lip",fit(dist,0,2*ch("range"),0,1))*(1-dist)) : @P 2 Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 30, 2017 Author Share Posted June 30, 2017 (edited) Taper: (3 axes in 1) you can delete the orig 3 separate Taper X/Y/Z attribexpression/snippet Taper @P; if(chi("axis")==0) { @P=set(self.x,self.y*chramp("profile",relbbox(@P).x)*ch("mult"),self.z*chramp("profile",relbbox(@P).x)*ch("mult")); } else { if(chi("axis")==1) { @P=set(self.x*chramp("profile",relbbox(@P).y)*ch("mult"),self.y,self.z*chramp("profile",relbbox(@P).y)*ch("mult")); } else { @P=set(self.x*chramp("profile",relbbox(@P).z)*ch("mult"),self.y*chramp("profile",relbbox(@P).z)*ch("mult"),self.z); } } Edited January 3, 2018 by Noobini 1 Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 30, 2017 Author Share Posted June 30, 2017 (edited) Collision Deform: improved with N Bias attribexpression/snippet Collision Deform @P; int nearestptid = nearpoint(1,@P); vector nearestpt = point(1,"P",nearestptid); vector nearestptn = normalize(point(1,"N",nearestptid)); float dist=length(@P-nearestpt); @P = dist<ch("range")?lerp(@P,@P+(@N*ch("n_bias"))+(nearestptn*(1-ch("n_bias"))),ch("deform")*chramp("lip",fit(dist,0,2*ch("range"),0,1))*(1-dist)) : @P LippySpheres.hipnc Edited January 3, 2018 by Noobini 1 Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 30, 2017 Author Share Posted June 30, 2017 (edited) I'm not yet capable of doing FLIP sims but just thinking ahead if it's possible to advect/art direct a crown splash with geo like this...(or use in pyro...) Edited June 30, 2017 by Noobini 3 Quote Link to comment Share on other sites More sharing options...
Noobini Posted July 1, 2017 Author Share Posted July 1, 2017 (edited) Melt: (less Z fighting) attribexpression/snippet Melt set(@P.x*ch("melt")*chramp("effect",relbbox(@P).y)+@P.x,clamp(@P.y + ch("thickness")*@N.y - ch("melt"),getbbox_min(0).y+ch("thickness")*@N.y,getbbox_max(0).y),@P.z*ch("melt")*chramp("effect",relbbox(@P).y)+@P.z) Edited January 3, 2018 by Noobini 1 Quote Link to comment Share on other sites More sharing options...
Noobini Posted July 6, 2017 Author Share Posted July 6, 2017 (edited) Neighbourhood Watch: (NB: to be found in Group Expression)...for quickly identifying 'polar' verts. # # Group Expression # groupexpression/snippet Neighbourhood Watch neighbourcount(0,@ptnum)==chi("count") Edited January 3, 2018 by Noobini 1 Quote Link to comment Share on other sites More sharing options...
