Creating Translucency map from Diffuse
What if you invert the specular, but still matte it by the alpha? Then follow it up with some mild color correction or levels to make it look nicer... I don't think I have ever used a translucency map. Most of my map work is diffuse, specular, bump or normal. An occasional AO multiplied on top if it is available.
Edited by Atom
