art3mis Posted June 25, 2017 Share Posted June 25, 2017 (edited) I am trying to use the Attribute randomize to randomize just one value, rotation around z axis. But even after reading the documentation am confused. What is meant by 4 dimensions? What exact parameter would I use for Middle Value Attribute? When using 4 dimensions in the spreadsheet I see orient[0] orient[1] orient[2] orient[3] Edited June 25, 2017 by art3mis Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 25, 2017 Share Posted June 25, 2017 my guess is by default, it's randomizing Cd which is vec4:rgb and alpha ? No I don't know about that Middle Value thing (probably specific to Cauchy Lorentz) You could have just used the default randomizing Cd...then later do Cd.r x 360 but the sample setup. I've just used 1 dimension for orient (just a number from 0 to 360) hence the 1st entry is set to max 360...then later on...I used it directly instead of a 'multiply' RandomOrient.hipnc Quote Link to comment Share on other sites More sharing options...
