salah_hussein Posted July 6, 2017 Share Posted July 6, 2017 (edited) Hi all I need help with Arnold for Houdini installation I have this problem , Please find it in the attached file <<< Traceback (most recent call last): File "arnold_light", line 6, in <module> File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.557/houdini/python2.7libs\objecttoolutils.py", line 482, in genericCameraLightTool camlight = genericTool(scriptargs, nodetypename, nodename, clicktoplace) File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.557/houdini/python2.7libs\toolutils.py", line 1251, in new_func return function(*args, **kwargs) File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.557/houdini/python2.7libs\objecttoolutils.py", line 441, in genericTool exact_node_type = exact_node_type) File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.557/houdini/python2.7libs\objecttoolutils.py", line 379, in genericObjNodeGeneratorTool exact_node_type ) File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.557/houdini/python2.7libs\objecttoolutils.py", line 320, in createObjNode exact_type_name = exact_node_type) File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.557/houdini/python2.7libs\houpythonportion.py", line 1287, in decorator return func(*args, **kwargs) File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.557/houdini/python2.7libs\hou.py", line 6585, in createNode return _hou.Node_createNode(*args, **kwargs) MatchDefinitionError: Failed to match node type definition. Error: Bad node type found: arnold_vopnet in /obj/arnold_light1/shopnet. Bad node type found: arnold_light in /obj/arnold_light1/shopnet/arnold_vopnet. Warning: Ignoring data for locked node: arnold_light1/shopnet/arnold_vopnet/OUT_light Ignoring data for locked node: arnold_light1/shopnet/arnold_vopnet/OUT_light Ignoring data for locked node: arnold_light1/shopnet/arnold_vopnet/OUT_light >>> Thanks Salah Edited July 6, 2017 by salah_hussein Quote Link to comment Share on other sites More sharing options...
MaximumsProductions Posted May 7, 2018 Share Posted May 7, 2018 (edited) Hate to revive thread, but don't see reason to start new one, since I have this error as well but more so it's related to anything arnold in Houdini. (This is just unlicensed arnold for now) Having issue with Arnold to Houdini Indie. Windows 10. Houdini 16.5.439. Arnold = htoa-3.0.1_r0f08864_houdini-16.5.439_windows I can't seem to get past this issue after many many hours. Things that are weird are some filepaths in that error have mismatched forward and back slashes. I wasn't sure how to fix that or why it would do that in the first place. I have redshift, but I'm not going to add path just to keep things simple. Python I added just in case it was sourcing incorrect python version.. doesn't change result of error. Other issues that may be similar are something to do with the visual studio side of things. tried uninstalling visual studio 2017. reinstalling 2017, uninstalling 2015, installing 2015. adding DSO error check in env variables = Houdini DSO error will say (127) Couldn't load. C:/Users/Max/htoa/htoa-3.0.1_r0f08864_houdini-16.5.439/htoa-3.0.1_r0f08864_houdini-16.5.439/dso/htoa_core.dll. This is probably because this file was intended for use with a different version of houdini (yet the versions match up less I'm crazy.) #HOUDINI_USE_HFS_PYTHON = 1 # htoa config start PATH = "$PATH;C:/Users/Max/htoa/htoa-3.0.1_r0f08864_houdini-16.5.439/htoa-3.0.1_r0f08864_houdini-${HOUDINI_VERSION}/scripts/bin" HOUDINI_PATH = "C:/Users/Max/htoa/htoa-3.0.1_r0f08864_houdini-16.5.439/htoa-3.0.1_r0f08864_houdini-${HOUDINI_VERSION};&" # htoa config end I've also tried hardcoded versions of the path and houdini paths C:\Users\Max\htoa\htoa-3.0.1_r0f08864_houdini-16.5.439\htoa-3.0.1_r0f08864_houdini-16.5.439 C:\Users\Max\htoa\htoa-3.0.1_r0f08864_houdini-16.5.439\htoa-3.0.1_r0f08864_houdini-16.5.439/scripts/bin I've tried multiple reinstalls of houdini and arnold as well as multiple versions of each. If anything I'd like a way to reset everything and not have this problem at all lol. I've installed it on a friends computer just fine, so not sure why I'm messing stuff up. Thanks if anyone knows any solution or ideas. I've had a few people try to help and am very grateful. few ideas were to check vcredist_x64.exe and install that. which I already had unfortunately so thats the whole visual studio stuff. and check my script error locations and see if they were in read only - they were not and they had full privileges. Edited August 1, 2018 by MaximumsProductions Quote Link to comment Share on other sites More sharing options...
okafor Posted April 19, 2019 Share Posted April 19, 2019 Hi Peon, Did you ever get a solution? Having exactly same issue. Thanks. Quote Link to comment Share on other sites More sharing options...
ahmedhindy Posted March 30, 2021 Share Posted March 30, 2021 Another revival 2 years later, facing same problem here Quote Link to comment Share on other sites More sharing options...
r-a-n-d-o-m Posted June 3, 2022 Share Posted June 3, 2022 (edited) might be you are using the Apprentice version and trying to use Arnold with it. Does not work. You need another Houdini version. Edited June 3, 2022 by r-a-n-d-o-m Quote Link to comment Share on other sites More sharing options...
