edge divide Question
julca
Oh yes ! That's a better way.
I still need 4 selections for each polysplit SOP instead of a unique "real working like in any other 3d app" edgedivide SOP with one set of edges..
Anyway, it do the job for this time, Thank you for your time !
You are looking for this then (use Subdiv SOP and OpenSubdiv Bilinear Algo):
That's a way but you need to manually select and delete some edges before and then apply uniformly opensubdiv.
Also, it don't suit my need because I need more subdiv in one direction. Your solution you've post just before are the best in my case.
But it's a method that's good to know, thank you ;) !
ps: Is there someone that's build its own edgedivide SOP which work with any selection order ?
8 minutes ago, LaidlawFX said:
A warning about OpenSubdiv Bilinear it will crash frequently on complex geometry, and SideFX can't do much about it because it's the open source code that can't handle it.
Ok, Thank you for the info.
