Srocaboy Posted July 18, 2017 Share Posted July 18, 2017 Hello everyone ! I try to fracture a box with the "voronoifracturepoints" Is it possible to fracture this box only in a predefined area, such as the blue area on the image?Thanks !!! VoronoiFracturePoints.hipnc Quote Link to comment Share on other sites More sharing options...
Sepu Posted July 18, 2017 Share Posted July 18, 2017 that is what you are doing with the ISO Offset, you set up to use on that area, so the voroni is just getting the effect in that area. So Im not sure if I understand correctly what you are trying to do. Quote Link to comment Share on other sites More sharing options...
Srocaboy Posted July 18, 2017 Author Share Posted July 18, 2017 Thank you for your answer The ISO Offeset just serves to place the voronoi fracture towards the center of the box. But this one doesn't limit the points of the fracture to the zone the iso offset. Look in the attached image, 5 points is found outside L'iso offset Quote Link to comment Share on other sites More sharing options...
Noobini Posted July 18, 2017 Share Posted July 18, 2017 (edited) agree with sepu....the ISO Offset is already doing its job, so simply delete your voronoifracturepoints4...and feed scatter points directly to voronoifracture1 (with more than 1 point that is)... Edited July 18, 2017 by Noobini Quote Link to comment Share on other sites More sharing options...
Noobini Posted July 18, 2017 Share Posted July 18, 2017 if you insist on using the voronoifracturepoints for whatever reason.....tone down the Impact radius...try 0.5, 0.5 ,0.5 instead of some huge numbers that's currently causing you problems Quote Link to comment Share on other sites More sharing options...
Srocaboy Posted July 18, 2017 Author Share Posted July 18, 2017 (edited) THANK YOU How could not i think about it... Edited July 18, 2017 by Srocaboy Quote Link to comment Share on other sites More sharing options...
