(redshift)pause and resume large render sequence
A current 20 second sequence is going to take about 60 hours total rendering time at roughly 8 minutes a frame. I’ve never rendered a sequence this large before.
With Redshift, what is the most efficient way of pausing and resuming a render without losing any frames?
I’d like to render only in the evening, canceling or pausing every morning.
I anticipate having to reboot my machine several times as well.
There is a Pause and Interrupt button on the dialog that pops up when rendering to disk. Use those buttons.
Restarting in the middle of a sequence can only be achieved if your scene has no simulations that need to cook. So pre-bake all things before you render if you expect your long render might be interrupted.
Yep, you're right. Baking is typically associated with texture map and caching is more about geometry. The main take away is to pre-calculate as much data as possible so at render time your computer does  not have to cook a frame.
