flourish Posted August 7, 2017 Share Posted August 7, 2017 (edited) Hello all, Newbie calling for help here. Now, more angry and with less hair... I am trying to export out an alembic file that will have my packed fracture in a grouped hierarchy rather then a solid piece of geometry. My end product would be an alembic that I can auto assign bones(via script) to each piece of geo inside of maya. From there I would like to export out as an FBX. My geometry setup in houdini does have an Assemble node with Create Groups, Create name Attribute and create Packed Geometry selected. In my fracture voronoi I have an attribute created called piece. Also in my voronoi tab under groups Ive selected create groups with named prefix, interior and exterior groups. I dont know if Im setting up my tree wrong in my fractured Object (Door) or if my settings to render out with a ROP Alembic are jacked. So my question is 2 fold, Am I setting up my packed fracture correctly to give me individual pieces come alembic time. AND are there special settings/ and or combination of settings of both. Ive read the manual, rumbled through sites and still no bueno. I've included my scene for further diagnoses. ANY help would be greatly appreciated. I've also tried incorporating Laidlaw's RBD/FBX export into my hip and couldn't get it to work. On that note any FBX workflow that can be recomended. I tried the game tab RBD to FBX export but I'm confused as to what node to export I should select in my file. Everything Ive tried so far just throws an error Again I appreciate ur help! DoorExplode_OD_v005.hip Edited August 7, 2017 by flourish Quote Link to comment Share on other sites More sharing options...
MENOZ Posted May 24, 2018 Share Posted May 24, 2018 any luck with this? Quote Link to comment Share on other sites More sharing options...
3dome Posted May 24, 2018 Share Posted May 24, 2018 on the rop alembic output there's the option to build Hierachy from Attribute. that should do the trick Quote Link to comment Share on other sites More sharing options...
benne5 Posted May 24, 2018 Share Posted May 24, 2018 Alternatively, you can use the rbd to fbx exporter directly out of Houdini. Quote Link to comment Share on other sites More sharing options...
