changing a parameter on everynode in my scene
highdensity
just selected all of the node that are the same and change whatever you have to... it should work.
If they are in different levels, look at the "opchange" help on the Textport
Edited by Sepu
sorry i forgot to specify, they are not at the same level. i will look into that, thx !
Edited by highdensity
typo
Surely with a python script that can look something like this:
for object in hou.node("/obj").children():
  if object.type().name() == "the type you're searching for":
    for node in object.children():
      if ... //some other condition, if any
      node.set... //and here you set the parameter you want the value you want
i dont know much about programming i have a hard time figuring out what i have to write at the last line. i want to change the load as setting to load houdini geometry. if i hover on load as the name show up as loadmode. i tried stuff like node.setloadmode(loadhoudinigeometry): but its not working.. :unsure:
