Even Number Delete
dreamagrery2
here you are...
(note: you said delete the groups...NOT the actual points themselves, so don't expect to see the points disappearing, if you middleclick on the python node, you'd see the EVEN groups are gone)
ahhh...what the hell, I've updated the file so you can delete the points as well if you wish..it was a good exercise for me to go thru (1st time doing Python....ever !!!)
DeleteEvenGroups.hipnc
Edited by Noobini
  On 8/30/2017 at 3:41 AM, Noobini said:
here you are...
DeleteEvenGroups.hipncFetching info...
Thanks @
  • Illusionist. I really appreciate your help and this will help me in the future. It seems that this approach works with points. Might you have a practical approach for this with groups alone-- where the copy SOP creates the groups and you delete only even number groups? Thanks in advance!
you can do is again with the modulus function here is an example. you should show up a screenshot how your groups are builds.
Check your spreadsheet when you open the file, I created a group for each sphere with the partition SOP then I use the enumerate SOP to give some some kind of ID to the groups then in the wrangle I just do
if(i@index % 2) {
    i@idx = 1;
to check odd and even, after that in the delete sop you do
@idx==0
to delete your even Groups/Prims.
deletebyModulus.hipFetching info...
Edited by Sepu
it's doing exactly what you want: deleting (point) groups, not the points themselves. THIS IS WHAT YOU ASKED FOR.
Then i even gave you the option to delete the actual points in case that was your real intention....what more do i have to do ?
Why point groups ? cos you said your groups are pointgroup_xyz
Edited by Noobini
You're right! I just couldn't get my head around it! This is a way different approach than what I am used to. Thank you!
if(i@index % 2) {
    i@idx = 1;
@idx==0
to delete your even Groups.
This is perfect. It seems much easier to understand. Thank you!!
i don't mean to be rude since i have much less experience than alot of ppl here...but i think using idx approach is flawed. if i manually select some points, assign them to pointgroup_0, then again manually select some points assign them to pointgroup_1....rinse, repeat.....(think clustering)
Now i want to delete the pointgroup_ that are even numbered.....it has nothing to do with point idx...it's simply the last digit of the groupnames.
(i've yet to open up sepu's file to dissect tho, will do later...so that could be perfect for all i know :) )
Edited by Noobini
here's one that deletes any group that evenly named. (ie. your groups can be of points, edges or prims)
node = hou.pwd()
geo = node.geometry()
# Add code to modify contents of geo.
# Use drop down menu to select examples.
myPgroups = geo.pointGroups()
myEgroups = geo.edgeGroups()
myPrimgroups = geo.primGroups()
# make up your own combination here for whatever you want to check
checkgroups = myPgroups + myEgroups + myPrimgroups
for group in checkgroups:
    lastchar = int(group.name()[-1])
    if lastchar % 2 == 0:
        # remove the '#' from next line if you DO want the points deleted as well
        #geo.deletePoints(group.points())
        # delete the group
        group.destroy()
I stress again, it deletes groups....NOT actually deleting points/edges/prims.
This is because the spec says: "How do I delete only the even number groups? "
If your intention is to delete actual geometry.....the points/edges/prims/copied geo....then be clear in the spec.
