neurostudio Posted September 8, 2017 Share Posted September 8, 2017 (edited) Hey there, I put together this dynamic fracturing following a tutorial. When I append a rop to export .abc, just the glue constraints splines get transferred, but not the geometry. Maybe the groups are not transferring correctly through the hierarchy? Can't figure out what I am missing. #n00b Thanks in advance. Here's the animated .abc I am using and attached is the .hip. breakdance.hip Edited September 13, 2017 by neurostudio Quote Link to comment Share on other sites More sharing options...
Atom Posted September 8, 2017 Share Posted September 8, 2017 Are you using the /out context? Try dropping down an Alembic node in the /out context. You get a lot more controls. Quote Link to comment Share on other sites More sharing options...
neurostudio Posted September 8, 2017 Author Share Posted September 8, 2017 6 hours ago, Atom said: Are you using the /out context? Try dropping down an Alembic node in the /out context. You get a lot more controls. Thank you Atom I can't exactly follow. I just placed the ROP_alembic at the end of the hierarchy. Quote Link to comment Share on other sites More sharing options...
Atom Posted September 10, 2017 Share Posted September 10, 2017 That is the SOP context, try dropping down an Alembic node in the /out context. Quote Link to comment Share on other sites More sharing options...
neurostudio Posted September 11, 2017 Author Share Posted September 11, 2017 19 hours ago, Atom said: That is the SOP context, try dropping down an Alembic node in the /out context. Thank you for this! I'll try to make sense of it and report back! A friend made me notice there's something weird in the way the connect adjacent points behaves. I'll look in to that as well. Quote Link to comment Share on other sites More sharing options...
neurostudio Posted September 12, 2017 Author Share Posted September 12, 2017 unfortunately even rendering through the /out context doesn't not transfer the actual the geometry. Quote Link to comment Share on other sites More sharing options...
kev2 Posted September 13, 2017 Share Posted September 13, 2017 You were one node away. Add DOP Import node in SOPs and bring the Packed Frags back in from DOPs. Then File > Export Alembic Scene. breakdance.hiplc Quote Link to comment Share on other sites More sharing options...
neurostudio Posted September 13, 2017 Author Share Posted September 13, 2017 7 hours ago, kev2 said: You were one node away. Add DOP Import node in SOPs and bring the Packed Frags back in from DOPs. Then File > Export Alembic Scene. breakdance.hiplc Thank you so much!!!!!! That's silly and really screams #newbie Quote Link to comment Share on other sites More sharing options...
kev2 Posted September 13, 2017 Share Posted September 13, 2017 Sure thing. We've all been there, Houdini is a minefield of gotchas. 1 Quote Link to comment Share on other sites More sharing options...
