[SOLVED] Dynamic fracturing | can't export geometry (.abc)
Hey there,
I put together this dynamic fracturing following a tutorial. When I append a rop to export .abc, just the glue constraints splines  get transferred, but not the geometry.
Maybe the groups are not transferring correctly through the hierarchy?
Can't figure out what I am missing. #n00b
Thanks in advance.
Here's the animated .abc I am using and attached is the .hip.
breakdance.hip
Edited by neurostudio
19 hours ago, Atom said:
That is the SOP context, try dropping down an Alembic node in the /out context.
Thank you for this! I'll try to make sense of it and report back!
A friend made me notice there's something weird in the way the connect adjacent points behaves. I'll look in to that as well.
