art3mis Posted September 28, 2017 Share Posted September 28, 2017 (edited) Having a heck of a time simply trying to install PG Bokeh for Nuke 11 NC on my Ubuntu setup. My understanding is you need to alter the environment variables for Nuke? Feedback direct from peregrine said I should edit my .bashrc file So, I added the following line to my bash.bashrc file in /etc/ Quote export NUKE_PATH=/home/jim/Nuke11.0v2 Expand And copied the downloaded PG Boken blugin folder to the plugins folder inside the above Nuke directory What is the difference between bash.bashrc and the hidden .bashrc in my home directory? If I try and edit the latter I get an error 'editing files in a writable directory is not permitted' Still no luck Can anyone help? Wouldn't it be easier to make the plugin an actual installer? Edited September 28, 2017 by art3mis Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 28, 2017 Share Posted September 28, 2017 On 9/28/2017 at 1:25 AM, art3mis said: Can anyone help? Wouldn't it be easier to make the plugin an actual installer? Expand Probably because NC doesn't work with compiled plugins IIRC. You'd better also get used to Unix style installations as an installers are not really every going to happen for high-end customised software. Quote Link to comment Share on other sites More sharing options...
art3mis Posted September 28, 2017 Author Share Posted September 28, 2017 Thanks Marty Have you used Pg Bokeh before? Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 28, 2017 Share Posted September 28, 2017 yes - it's super slow as it's single threaded but is very good quality. So you should use ZDefocus when setting up and copy those settings/look to render in PgBokeh. Use ZDefocus if you can as it's GPU accelerated and does everything except deep defocusing. Quote Link to comment Share on other sites More sharing options...
