Atom Posted October 2, 2017 Share Posted October 2, 2017 (edited) Does anyone have any modeling tips to fix up a bad boolean cut? Basically I am trying to convert a hand drawn shape into an all quads polygon result. So I boolean subtract the extruded outline shape from a basic grid. This does give me a mostly quads output but there are stray points along the edges that need cleaned up. Edited October 4, 2017 by Atom Quote Link to comment Share on other sites More sharing options...
DaJuice Posted October 3, 2017 Share Posted October 3, 2017 You can append a Facet SOP and turn on Remove Inline Points. The results are not always perfect though. Quote Link to comment Share on other sites More sharing options...
Atom Posted October 3, 2017 Author Share Posted October 3, 2017 (edited) Yeah, I did try that and it does not work on my particular geometry. I also tried Fuse which does work, but gobbles up other valid points as well. Maybe some magic VEX code is needed that can isolate those lone points? Edited October 3, 2017 by Atom Quote Link to comment Share on other sites More sharing options...
Nache Posted October 3, 2017 Share Posted October 3, 2017 Hi there! In your case that might be a solution. It remove point if the angle is more than a threshold and as 2 neighbours (border in your case). int nn = neighbourcount(0,@ptnum); @dot; if(nn == 2) { int Lp[] = neighbours(0, @ptnum); vector pos1 = point(0,"P",Lp[0]); vector pos2 = point(0,"P",Lp[1]); pos1 = normalize(pos1-@P); pos2 = normalize(pos2-@P); float dot = dot(pos1,pos2); @dot = dot; if(abs(dot)>0.995) //0.995 is the angle threshold { removepoint(0,@ptnum); } } I hope it will do the trick for you, Gab. 4 Quote Link to comment Share on other sites More sharing options...
Atom Posted October 4, 2017 Author Share Posted October 4, 2017 (edited) Thanks Gabriel. That gets about 95% of the problem points. In the GIF I am turning on and off the attribute wrangle with your code. When I zoom into look at the final problem point I notice that it is essentially a small triangle. Do you have any code that might detect small triangles for removal? Edited October 4, 2017 by Atom Quote Link to comment Share on other sites More sharing options...
Atom Posted October 4, 2017 Author Share Posted October 4, 2017 (edited) Actually fuse with a smaller distance picks up those really close small triangles. Then follow that up with your code in the attribute wrangle and it looks like a working solution. The only side effect seems to be that some of the quads are slightly slanted. Edited October 4, 2017 by Atom 1 Quote Link to comment Share on other sites More sharing options...
