art3mis Posted October 23, 2017 Share Posted October 23, 2017 Hi Has anyone reading this ever tried to create a 3D city using data from http://www.openstreetmap.org What are the steps are involved? Can you recommend any tutorials? Quote Link to comment Share on other sites More sharing options...
f1480187 Posted October 23, 2017 Share Posted October 23, 2017 (edited) There are free tutorial and working implementation somewhere in SESI's GitHub exist. Also, someone posted OSM importer 1-2 years ago here on odforum. Here is a bit of my experience on this. At first, you should make yourself familiar with OSM format: nice wiki page on OSM specs . Export some small excerpt around your house and inspect it. Simple Python OSM loader for xml rectangles exported from the website or from Overpass API: from collections import namedtuple from xml.etree.cElementTree import parse Bounds = namedtuple('Bounds', 'bounds') Node = namedtuple('Node', 'id tags latlon') Way = namedtuple('Way', 'id tags nodes') Relation = namedtuple('Relation', 'id tags members') Member = namedtuple('Member', 'ref role') def _id(e): try: return long(e.attrib['id']) except KeyError: return long(e.attrib['ref']) def _tags(e): tags = {} for tag in e.findall('tag'): a = tag.attrib tags[unicode(a['k'])] = unicode(a['v']) return tags def osm_load(file_or_fp): root = parse(file_or_fp).getroot() data = [] # Load bounds element. attrib = root.find('bounds').attrib coords = map(float, (attrib['minlat'], attrib['minlon'], attrib['maxlat'], attrib['maxlon'])) data.append(Bounds(tuple(coords))) # Load nodes. node_ids = {} for e in root.findall('node'): latlon = (float(e.attrib['lat']), float(e.attrib['lon'])) node = Node(_id(e), _tags(e), latlon) node_ids[node.id] = node data.append(node) # Load ways. way_ids = {} for e in root.findall('way'): nodes = [node_ids[_id(n)] for n in e.findall('nd')] way = Way(_id(e), _tags(e), nodes) way_ids[way.id] = way data.append(way) # Load relations. for e in root.findall('relation'): members = [] for m in e.findall('member'): ids = node_ids if m.attrib['type'] == 'node' else way_ids members.append(Member(ids.get(_id(m)), m.attrib['role'])) data.append(Relation(_id(e), _tags(e), members)) return data It will convert OSM structure into Python objects. OSM file consists of Bounds, Nodes, Ways, Relations and its Members with their own simple attribute structures and optional child tags. "Useless" attributes were dropped, e.g. fully-described Nodes could look like this: namedtuple('Node', 'id visible version changeset timestamp user uid tags latlon') So, the above code can be modified to include any of those members too. Nodes are similar to Houdini points with attributes. Isolated Nodes are used for information, rather than defining map features. Other nodes are just like primitives' points, they have no information and can be shared between primitives. import math def mercator(lat, lon): x = 6378137.0 * math.radians(lon) y = 180.0 / math.pi * math.log(math.tan(math.pi/4.0 + lat * (math.pi/180.0)/2.0)) * (x/lon) return x, y # Make nodes as points. points = {} for node in (n for n in data if type(n) is Node): pt = geo.createPoint() points[node.id] = pt # Place to copy useful attributes defined on Node object, like: # pt.setAttribValue('attrib', node.attrib) x, y = mercator(*node.latlon) pt.setPosition((x-pivotx, y-pivoty, 0.0)) Ways are like Houdini polygon curves. They have their attributes and refer to a bunch of Nodes: # Make ways as primitives. for way in (w for w in data if type(w) is Way): prim = geo.createPolygon() # Place to copy useful attributes defined on Way object, like: # prim.setAttribValue('attrib', way.attrib) prim.setIsClosed(way.nodes[0] is way.nodes[-1]) if prim.isClosed(): way.nodes.pop() pts = [points[node.id] for node in way.nodes] # Gauss's area determines the winding order. gauss_area = 0.0 for i in range(len(pts)): ax, ay, _ = pts[i].position() bx, by, _ = pts[(i+1) % len(pts)].position() gauss_area += (bx-ax) * (by+ay) if gauss_area < 0.0: pts.reverse() for pt in pts: prim.addVertex(pt) That should define most of the city: The trickiest part is to handle Relations and Members. This is important part of OSM specs defining areas and complex buildings sharing some common relation: Basically, they help to define what is a fence, a building block or inner open space. They make use of tags, which is totally human-generated content. There are many challenges with them if you try to make them generic enough to handle any input map. Even without proper Relations handling, when we made primitives from Ways we already had something decent, that can work on large-scale: Currently, this is just a stalled project on my disk, I have no time on it at this moment, so, I'll simply upload it there: osm.zip Edited October 23, 2017 by f1480187 3 Quote Link to comment Share on other sites More sharing options...
bonsak Posted October 23, 2017 Share Posted October 23, 2017 Heres the github link: https://github.com/sideeffects/GameDevelopmentToolset Quote Link to comment Share on other sites More sharing options...
art3mis Posted October 23, 2017 Author Share Posted October 23, 2017 Thanks guys! Was wondering what to focus on for my next personal project. Quote Link to comment Share on other sites More sharing options...
stinzen Posted May 15, 2020 Share Posted May 15, 2020 Asking here since I had a very hard time finding any information about this. Is it possible to derive the driving direction from the imported OSM data? It can be seen as arrows on oneway streets on openstreetmap.org and my mapping friends tell me this is stored in the Node in OSM but I can't figure out if that information is available in in Houdini using the OSM_Import node. Quote Link to comment Share on other sites More sharing options...
stinzen Posted May 18, 2020 Share Posted May 18, 2020 I figured this out, the point numbers show the driving directions, ascending numbers = driving direction. Quote Link to comment Share on other sites More sharing options...
